too bad i only have one cree light so far, the P1D CE, but all the shots in my corridor beamshots are about 30m, or just a little shy of 100ft. see sigline for link.
but your question is a little confusing and i'm not sure what you are asking. because the throw of a fixed light source (in this instance, i assume the new Cree XRE) is almost exclusively dependent on the reflector/lens/optic. so as the thread with Newbie's aspherical lens above showed, you can basically make a Cree into a laser-like beam if you want. it all depends on how you design your reflector/lens/optic. in general, larger = better in terms of throw.
clearly the current set of reflectors designed for luxeons or whatever, may not be optimal for the Crees. just as they were developed for the luxeon, new reflectors will have to be developed (or at the very least, tweaked) for the Crees.
so are you asking a) how far do Crees throw compared to X light source? or b) how far do current flashlights using Crees throw compared to one another? or c) something else? everything is a tradeoff.
regardless, with a fixed light source, putting out (one would assume) comparable light with comparable characteristics, they'd all "throw" or not throw the same. it's how the reflector is designed, that gives you a particular beam pattern, that is more important. for flood or throw or whatever.
