Well I received my Cree's and optics today from cutter. First change on the Blaster went fine. Well after the wife went to work and the kids went to bed, I figured I would go swap my Lux in the XP to the Cree P4. The swap went great and prelimary checks went well. The Cree was noticably brighter but with a relatively ugly beam (without diffuser). So I went in the basement and dremeled down the Cree optic considerably and was able to replace the Myo XP optics with this. In order to fit the optics the plastic spacer in the XP was ground down. I tested this against my wall and was really impressed with the beam both with and without the diffuser. It was noticably brighter and much more pleasant to look at. Now comes the bad part. When after making some adjustments to the way the LED sat, I must of nicked the positive wire where I could not see. So when it was all done, I wanted to verify the LED was centered and turned on the headlamp. Well there was no light, then after about a full second the all to familar and smelly puff of smoke!!! The positive wire I nicked shorted out and blew a surface mount transisitor. But somehow the Cree survived!!! YIPPEE, so I sacrificed my 70 dollar headlamp, but was able to keep the LED alive. Oh well, live and learn.
On another plus side, the MYO lux ended up being removed from the star and installed in my original FF, replacing a greenie.
No I am off to order a new XP since I ned a headlamp for my hike next month. As with falling off a bike and getting back on, I think I wil go for the mod again with the new on. I just hink it will be after my hike. Enjoy.
