Curious_character said:
I've used WD-40 for many years on a very wide range of materials, and have never found anything which it attacks. I'd appreciate very much hearing from anyone knowing of any plastic or other material harmed by WD-40.
c_c
Being a patroleum based solvent, WD-40 desolves like based materials. Some desolveable materials react at different rates. WD doesn't attack, it desolves. One of the materials that WD desolves quickly is road tar. WD is probably the best road tar remover on the planet. It works great on cars, because it usually won't harm the finish. The reason it doesn't hurt the finish or most plastics, which are patroleum materials, is because plastics desolve at a much slower rate. So that aspect gives one time to wash the WD off without harm. Over time, WD can discolor plastics. Sure you can put WD on plastics and not notice anything for a long time. I don't recomend you leave it on your car's finish. And I certainly wouldn't let it get on a plastic flashlight lens that I want to remain as clear as possible. To protect against Oxide on a battery, WD is OK. You would just want to be carefull with it.
Contrary to popular belief, WD is not a lubricant either. Yea, it claims to "Quiets sticky mechanisms". Heck, Milk will do that for a while. Go out in your garage and read the label on your can of WD. The word "lubricant" is not even on there.
Through experience I have found that WD is a great penetrant, desolver, and cleaner. I have also found that Tri-flow with Teflon to be a great product that does all those things, AND is also a fabulous lubricant.
And no, I don't work for Tri-Flow.
JMHO Good Luck.
