Imalent
Results 1 to 8 of 8
Thread: Surefire G2 LED
    Post Surefire G2 LED
    What are all of the possible LED mods/lamps avaliable for a G2? I already have a 3.7V Xenon with a 17670 battery. Thanks
    Nightstalker101
    Dec 2005
    Kingwood, TX
    Default Re: Surefire G2 LED
    BOG 3 watt is what I have. It's ok, especially if you like the G2 form factor.
    EDC = Quark Mini AA (14500). Favorites I own: Fenix PD32UE, PD35, etc....
    Will that work with a 3.7volt battery as well as it will with two rechargeable CR123 (3.7 v each)? Thanks
    Nightstalker101
    Jul 2006
    N 03°13.884° / E 101°29.329°
    Flashaholic alantch's Avatar
    Jul 2006
    GMT +8
    Is the BOG 3W same as the G&P 3W and would the G&P 3W work with 2 x RCR123s safely? TQ
    Dec 2005
    Kingwood, TX
    Quote Originally Posted by alantch
    I understand they are the same. Will they work with 2 x RCR123's, I don't know.
    Input voltage on the 3W, 5W, and new 7W is 4.5 - 9V
    Hope that helps.
    Regards,
    Flavio
    BugoutGearUSA.com
    Oct 2003
    Chicago Suburbia, IL
    BOG and G&P are selling essentially the same item.
    I can highly recommend BugOutGear USA for the 3W / 5W and 7W modules. I've got them all in use.
    I've set up several G2's with the 3W LED module. For my Father-in-law, it runs off of (2) 3.0v 123 cells for 6 volts. I run mine off of the 3.7v li-Ion 17670. It can run off of (2) R123 cells no problem as well.
