Willabbott
Hopefully this is the proper place to post this, if not please move....
Ok, I've built a couple K2 3C mag conversions so far, but I had ordered a Royal Blue and Blue LuxI emmiter from sandwich shoppe to do some 3D mags.
Tonight I put them together, previously I had the royal blue temporarily in a 3C mag without any problems (seem to recall amp draw seemed ok)
Now I have them permanently installed, of course I didn't get Vf for the LED's when I bought them (Bin codes weren't listed/available)
So I built them, they work great, plenty bright, etc...
I put my multi-meter on the 10A setting, and placed the negative on the back of the batteries, and the positive on the lights body, and with 3 cells I get almost 2AMP (1.8-2.0 ish) so this made me go, hmm, overdriven big time... so I pulled one cell out of one of the lights and checked the draw again, this time getting .22 or so on the meter... This to me seems like what I should be seeing, but I find it hard to belive that there is such a difference between one cell to the other...
I don't know a lot about electronics, and am trying to learn what I can... is there one of the formulas (such as ohms law, etc) that explains what I'm seeing? I'm not great with math either, but is this the difference in 1.5V does it really add about 1.8A more current to the circuit. .22Amps seems under driven as if memory serves LuxI's are speced at 350ma, I know I could overdrive a little, but 2A has got to be enough to fry them in a short time frame I would think.
So, help me understand what's going on, if I'm doing something wrong, or 1 cell really makes that much of a difference.
I guess the solution is I need to get a dummy D cell and run them at the .22A rate, or get a converter board, which board should I get, simple easy to install and configure... I want to lean to use converter boards (regulation, etc) eventually I'm really interested in the multi-level converters, but it looks like they require that voltage be supplied from the batts to the board, and then a seperate switch circuit, so I'm guessing I would have to do something different besides just placing it inline from the switch to the LED
Help me understand, and please reccomend a solution, I'll order a dummy cell for each light or converter from Sandwich shoppe (or ???) on monday to fix these lights up proper.
[Edit] I know I can add a resistor as well to fix the voltage/current difference as well, which might be the solution to the blue light since it won't be used as much, but I want to learn how to use the converter boards, and if I'm going to tear it apart to fix it, I might as well learn more and add regulation to the mix, especially on the Royal Blue which is likely to see more use. [/EDIT]
