TechPro said:
I'm not sure though if I can pull off a machined aluminum head so I will probbably need to figure out a way to keep the plastic head cool or underdrive the cree to maintain a safe temp. over extended usage...heavy duty reflector and glass lens will be mandatory I suppose?
Actually, I don't think you need the heavy duty reflector and glass lens. What you need is a chunk of aluminum to act as a heat sink for your LED or LEDs.
Plastic is a thermal insulator, which will trap heat inside the head, raising its interior temperature. The aluminum heat sink will spread heat away from the LED lowering its junction temperature somewhat.
But, the surrounding plastic will prevent heat from escaping the head at a decent rate. So, the aluminum will get hotter, as will the LED junction, until the light has been running for awhile and thermal equilibrium is reached.
I'm not aware of any plastic Luxeon LED lights that run at or greater than 3 Watts.
PT makes a 3 Watt Luxeon plastic headlamp, the Apex, but it has a finned metal heat sink molded into the head, with metal fins exposed outside the head. The plastic UK 4AA eLED Zoom runs its 3 Watt Luxeon LED at about 2 Watts, presumably to prevent overheating and failure of the LED.
