waynejitsu, I will be doing the mod myself, I don't have specifics on how powerfull the drive circuit is on the gladius in mA, but I believe the gladius slightly overdrives a 3 watt luxeon, that and it will run on high output for 70 min. would have me guessing about a 1000mA drive. the cree outputs some 175 lumens at 1000mA although it's only rated @ 700 mA. This has me expecting much higher output assuming I can find the right reflector as the light is emmited in a much different pattern on the crees. The idea of daily use at a much dimmer setting AND having nearly twice the lumens leads me to believe the gladius would be the perfect modding light, cept for that whole voiding the warranty thing... as far as beam shots, I'll do my best but have been less than satisfied with the quality of the pix so far... I'll keep trying and keep you posted!
Nate
It seems I should be expecting the pattern to be more u2ish with the stock reflector....We'll see soon!
