Just curious. Last night while using my 60GT I noticed that when I turned the light off that the LED did not turn directly off. The LED seemed to flash to a super low setting then die off. This wasn't a long process but long enough that you can see it happen. The only reason that I noticed is that I was setting the light down on a table in the dark as I hit the switch and saw the glow as it hit the table. I picked it back up and each time I turn it off the same thing happens. It is not a clean "snap" off, it fades down each time then goes off. It is almost like you can see the light pulse once then fade and turn off.
I don't know if this has anything to do with the electronics, or if this is how it has always turned off. I was just curious for input. I still love the light just want to make sure that there isn't an issue developing within.
Thanks for the replies,
Marc
Marc
