Blindasabat, I cut off the lip on the base of the reflector so the silver metal ring on the Cree will go up into the reflector also.
Here are some good pictures of the cut-down reflector:
https://www.candlepowerforums.com/threads/146880
I do not think it will focus without doing this. I can't even remember if I tried it before cutting the reflector. I do not think I did. I had read other posts and just followed their lead(thanks CPF !)When you cut/sand/whatever the lip off, it also opens the diameter enough to fit the silver ring.
I will not use CR123 in this light. Mine has a resistor in the tailcap for low-beam and no resistor at all for high-beam.
Make sure you put something non-conductive between the top of the Cree and the reflector or it will short.
I had a TYOH Luxeon with 20mm IMS and DB1000 in it before the Cree.(heck of a combo to toss out eh !).
It is much brighter now.
