Personally, I'd probably make my own, using an old PR-2 incandescent flashlight bulb and a 5 MM red LED. (A red LED requires less than 3 volts to operate at full brightness, which makes it easy to use it in virtually any 2-cell flashlight that originally came with a PR-2 style bulb - no voltage up-converters or other fancy circuitry required).
Although it's been covered before, the conversion is easy: Crush the glass envelope on the original bulb with a pair of pliers, use a dremel tool to clean out any remaining 'innerds' inside the base of the bulb, and then solder a red LED to the bulb's center pin and metal base (long LED lead to the center pin, shorter LED lead to the metal base). Ideally, you would also want to solder a 68 or 75 ohm resistor in series with the longer lead, so as to keep the LED from drawing more than 0.02 amps of current. Install it in place of original bulb, and you're set.
