cchurchi
- Joined
- Aug 21, 2006
- Messages
- 256
What is the brightest 1X 18650 light? I assume it would be the Huntlight with the cree led. What about 2X 18650?
cchurchi said:What is the brightest 1X 18650 light? I assume it would be the Huntlight with the cree led. What about 2X 18650?
blahblahblah said:
Thank you for asking that!!Long John said:" Best 1X 18650 light" ..... best for what?
adirondackdestroyer said:The M1 Cree and the Huntlight FT-01 Cree look great. The only downfalls are the lack of regulation when using the 18650 cell. Both lights will have awesome regulation with 2 primary 123's, but that isn't what you're looking for. They will run for a very long time on the 18650 but will have a normal down slope.
The DX-RV from Lumapower has INCREDIBLE throw! Little has been released about it, but it could be awesome.
whc said:The M1 XR-E circuit provide constant forward current to LED from 3.8V to 8.4V. And the Huntlight FT-01x Cree provides constant forward current from 2.5 to 9V.
An newly charged 18650 is about 4.2V. So both flashlights will provide regulation for the LED when 18650 is used ...
I'm missing something here. An earlier post stated that a constant current is delivered to the LED over a wide range of battery voltages. That means that a constant power is delivered. Assuming that the regulator has more-or-less constant efficiency over the range, then the power delivered by the battery is constant. Run time will then be proportional to the energy contained in the battery.lexina said:True enough. The M1 using an 18650 will fall out of regulation when the voltage drops below 3.8V. There has been no run-time graph for the M1 using 2 X 16340s.
In terms of overall run-time the 18650 will win hands down but it would be interesting to know which configuration would maintain regulation longer. Although the 2 X 16340s start off at a much higher voltage, the capacity is only about a third of that of the 18650.
Curious_character said:I'm missing something here. An earlier post stated that a constant current is delivered to the LED over a wide range of battery voltages. That means that a constant power is delivered. Assuming that the regulator has more-or-less constant efficiency over the range, then the power delivered by the battery is constant. Run time will then be proportional to the energy contained in the battery.
c_c
If you maintain a constant current to the LED, its voltage stays constant. The power is the product of the voltage and current. So maintaining a constant current maintains a constant power. (I'm neglecting changes in LED voltage with temperature. I believe the voltage drops as temperature rises, so the power actually drops a bit as the LED heats up.)lexina said:I have to admit this is something I am not clear about and I hope someone more knowledgeable will chip in - i.e. does the regulator maintain a constant current OR constant power?
Except for simple resistor limiters, nearly all the regulated lights seem to have switching regulators. A switching regulator which maintains constant current to the LED takes less current from a high voltage battery than from a low voltage battery, maintaining a constant power (voltage times current) consumption from the battery. In practice, the efficiency will vary a bit with input voltage so the power won't be exactly constant, but close.I understand that the current draw of the M1-XRE is 750mA. Is this maintained irrespective of whether you use 2X16340 or 1X18650? If so, the run-time using 16340s would be approx 1 hr (ignoring losses) and using 18650 would be approx 3 hrs.
OR is the current draw lower when using 16340s because the voltage is higher? If this is the case, then, as you say, the run-time using 18650 would only be 47% greater.
Btw, apologies to cchurchi for going OT here!
