Figured I should stick to something I know a little about for my first thread. The tactical use of light. I am a full time SWAT / Patrol officer working in a pretty busy area 30 miles of Baltimore between RT 40 and RT 95.
I break down my tactical use of light into three areas-
Street contacts- typical walking up to people on self initiated contacts or response to calls. 6P carried in reaction hand. Most people get a slight blast of light in the face to see what there reaction is. Most of the time this pisses them off and they bring their hands up towards their face letting me see if they are holding anything. Normally I find that they open their hands as if trying to push the light away. This is good since I see palms and if they are trying to hide narcotics. If an assault were to ensue hammer fists into the face/neck, collarbone, chest and hands have proved effective. If I anticipate a problem taking someone into custody I have employed that the tactic of talking to an imaginary person over their shoulder, they turn to look and then look back at me, I give them a blast of light into the face and in that split second they close their eyes and I go hands on. This does not happen all the time but I have used it with good success.
Car stops- unlike what they are teaching in the academy I like to stop cars in the darkest areas I can so that I control all the light. I use my high beams; take down lights and spotlight to illuminate the suspect car. If done correctly you could film a picture behind the wall of light and the suspect could not see anything. I will make contact at the passenger side window being sure to never cross the path of my lights.
Building calls- working in the ghetto so long I seldom even attempt to find light switches and turn them on since they seldom work and just use my light. On a side not most light switches can be found approx 3.5 to 4 feet off the floor about 10-12 inches from the door frame. Good to know in the dark. When clearing rooms lights are used to strobe and never turned constant on until contact is made with a suspect. When clearing a house care must be taken to remember that you will get massive splash and reflections from mirrors and TVs. The reflection will have the same effect on you as it does the bad guy (blind the poop out of you if you fixate on it).
As previously stated my 1st line duty light is a SF 6P with a P60 bulb. I usually go through two batteries a month on nights. This is because of not using it for constant on. The eyes are the same as using pressure points. If you over stimulate them they will adapt to the stimuli. That is why I find it best to strobe for the best distraction.
When I am searching something I will go to an LED light Fenix or Gerber X5 since I need to only see, not stun.
After much research I settled on the SF L2 for off duty since most of the time all I need is the LED to navigate by but under stress you can use the reg lamp. Another plus I that the L2 is the closest light to being the same size a kubaton.
For tactical applications I don't like any clickie tail caps since if you are hit and the light is "on". Not a huge concern but big enough for me.
These are just some random thoughts.
