Dogliness
I prepared an auto detailing quiz just for the fun of it. If any of you are interesting in detailing the exterior of your car, I thought it might be of interest. I will post the quiz here, and the answers in post #2 tonight or tomorrow.
1. Detail in
a. The sun
b. The shade
c. The sun or shade, it makes no difference
2. When Detailing
a. Wear lots of jewelry, a big belt buckle, and metal buttons
b. Avoid wearing abrasive objects
c. Wear real expensive clothing to look your best
3. How many buckets should be used for washing?
a. One
b. Two
c. Three
4. When washing
a. Wash from the top down
b. Wash from the bottom up
c. The part of the car washed first makes no difference
d. Wash complete sections top to bottom before moving to the next section
5. When rinsing
a. Wash entire car before rinsing
b. Rinse areas washed periodically during the wash phase
c. Rinse with the windows open to clean the interior and exterior in one step
6. After the washing is completed
a. Rinse each panel again one at a time
b. Rinse the entire car with vertical strokes
c. Rinse from the top down with horizontal strokes
7. Drying
a. Sun dry
b. Dry with a beach towel
c. Blot-dry pooled water and then dry car with a microfiber drying towel
d. Dry with a microfiber towel, drying pooled water last
e. Drive car to wind dry
8. Claying
a. Use large piece of clay
b. Use clay to remove etch marks from water deposits
c. Use clay to remove contaminants
d. Two of the above are correct
e. All of the above
9. More on claying
a. Use plenty of clay lube
b. Work in the sun
c. Do not reshape the clay while claying
d. None of the above
10. Polishing
a. Use polish to remove contaminants
b. Use polish to remove etch marks from water deposits
c. Use polish to remove swirl marks and lights scratches
d. Use polish to remove oxidation
e. Three of the above are correct.
f. All of the above
11. More on Polishing
a. Always polish as the last step
b. Go from a less abrasive polish to a more abrasive polish
c. Polish will remove sealant
d. Polish will remove wax
e. Two of the above are correct
f. Three of the above are correct
12. Glaze
a. Glaze and sealant protect the paint equally well
b. Glaze helps hide imperfections
c. Glaze helps remove imperfections
13. Sealant
a. Sealants make it easier to remove contaminants
b. Sealants last up to two months
c. A good sealant can last six months or more
d. Sealants tend to be more labor intensive to apply than wax
e. a and b are correct
f. a and c are correct
14. Wax
a. Wax absorbs light
b. Wax protects against oxidation
c. Wax protects against contaminates
d. Too much wax will dull the finish
f. Two of the above are correct
g. None of the above are correct
15. Detailing order
a. Detail in the order that the above questions address detailing steps
b. Clay after polishing
c. Glaze after using sealant
d. Use sealant after waxing
1. Detail in
a. The sun
b. The shade
2. When Detailing
a. One
b. Two
c. Three
4. When washing
5. When rinsing
7. Drying
a. Sun dry
8. Claying
e. All of the above
9. More on claying
b. Work in the sun
10. Polishing
f. All of the above
12. Glaze
13. Sealant
14. Wax
15. Detailing order
