Can you be more specific? Is the tread stiff or the switch? Usually a stiff switch is better than a soft one I reckon but it should not be too stiff until you cant actually push it. if its the thread then try putting some lube on the o-rings and threads. Hope this helps
Actually the stiffen part is the switch and not the thread. Well, I never handle a twisty before this one so I have no idea how far the normal stiffness except I compare it with a Z57 clicky tailcap.
I too have a Z57 to compare, and the L1 is much stiffer. After a few days, I got used to it. In fact I welcome the stiffness and I use more twisty action on the L1. Maybe that the way a twisty is............
