Originally posted by logical:
Apparently it's just you and I Stingray.
<font size="2" face="Verdana, Arial">Not so fast. I currently have a 1992 Yamaha TDM 850. In case your not familiar with the bike, it looks similar to this one [only better!!
It has 10-valve parallel twin cylinder engine with a 360 crankshaft and twin counter balancers. After fitting an internally baffled, stainless steel "Super Trapp" exhaust system, rejetting the carbs and fitting a "K&N" air filter, I had it dynoed. The results were 72 ft./lbs. of torque @ 4,000 rpm, that's 10 ft./lbs. more than a Harley-Davidson 1200 Sportster!
Not only that, the power band extends from 2,000 rpm to the 8,500 rpm redline!
Currently, the bike is shod with "Michelin" Macadam 90s, one amber headlight [in addition to one white headlight, for greater visibility], custom stainless steel brackets for soft saddle bags [keeps them off the rear tire], stock saddle [not great but the "Corbin" I had, broke down in less than 2 years. I weigh 160 lbs. so I know its not that!] and a host of other refinements too numerous to list here.
Overall, I've been pretty happy with "Molly" [Good, dependable Irish name. I used to call it "Marvin the Martian", you can see why.], but that doesn't keep me from having a "wish list". Those bikes are as follows:
Aprilia Futura
BMW R1100S
Buell Lightning XB9S
KTM 950S Adventurer
In no way does this short list contain all the all the custom-built bikes that I have in mind. With that thought, I should end this particular post because I can go on about this subject as extensively as darell can go on about EVs.
Later,
Dan
