My cousin is leaving to Australia for a year on the 5th Feb and during his trip he will be travelling through the east coast in a caravan or motor home.
being a flashaholic I thought I should give him some lighting tools for the trip.
However i do not know what kind of light he may mostly need as i have never travelled in a caravan for extended periods.
I tot i might give him the Parthenon lantern i built for general wide area lighting ( can also be used to light up the entire camper ), a small flashlight with a wideish beam for close up general work ( P1D-CE ) and a larger one with some power and throw for everything else ( Quad XR-E mag 3D with shark driver ).
However.....I have a few problems:
There is a weight limit ( 22Kg ) on his luggage and he is already finding it very difficult not to go beyond the limit even without the lights as he needs to take a lot of other stuff for a 1 year trip.
This means that the parthenon is out as it is bulky and weighs about 5Kg on it's own.
this poses another problem for batteries as different recheargables need different chargers and add to weight and bulk.
Another problem is battery availability and cost as CR123 batts might be expensive and hard to find so the P1D-CE is a bit iffy at the mom.
so im guessing the best bet would be the quad XR-E Mag which i would give him without batteries to save on weight and he can buy the d size batts from there easily. it is dimmable for close range lighting and should bright enough for everything else, however it will not be good for area lighting unless i can come up with some collapsable diffusing cone which does not take too much away from brightness, also alk batteries will not be that good at high levels. he might be able to buy ni-mh batts there but not sure about a 12V car charger for them. it is also not that easy to carry being a bit bulky.
I do not have enough time to buy him something different from overseas but i could build something new from scratch as i do have a lathe and many XR-E's and optics.
so i'm in a bit of a dilemma.
Your opinoins and suggestions would be appreciated.
Thanks
Thanks
