Jan 27, 2007 #1 zx7dave Enlightened Joined Jan 12, 2007 Messages 601 Location Seattle I just got a Lighthound dropin 3 watt LED which replaces the stock LA. It was intended for my G2, but I can't get it to light in my G2. It works fine in my 6P and my C2. Could the problem be because the body og te G2 is not metal?
Jan 27, 2007 #2 G glockboy Flashlight Enthusiast Joined Aug 27, 2003 Messages 2,349 Location houston, tx Put a piece of foil paper to make ground contact and it will work.
Jan 27, 2007 #3 zx7dave Enlightened Joined Jan 12, 2007 Messages 601 Location Seattle Worked perfectly!! Thanks
Jan 27, 2007 #4 K kwando Newly Enlightened Joined Oct 11, 2005 Messages 64 there should be a ring that is recessed in the LA... take that out and drop it in your G2 to make contact...
Jan 28, 2007 #5 zx7dave Enlightened Joined Jan 12, 2007 Messages 601 Location Seattle I actually tried te ring option and it still wouldn't light...but the foil did the trick.
Jan 28, 2007 #6 X xm_8 Banned Joined Jul 14, 2006 Messages 85 Doesn't the 3 watt LED get too hot in a G2? Are there problems with running a 3 watt LED in a G2?
