WildChild
Like many other CPFers here, I bought some 10440 Li-Ion cells for my L0D. I liked the way it made it brighter and that every levels still worked because the light use PWM for dimming. But now! After some research and measurement, I, and probably many others, think that there should be a WARNING about using 10440 cells in this light. Here are some current measurement I've done on it on every levels:
Primary: 0.42A
Low: 0.18A
High: 1.23A
Li-Ion cells are often rated for a MAX discharge rate of 2C. Most 10440 Li-Ion cells have a capacity of 320 mAh. 2C is then 640 mA. I bought mines from AW and he said that the max discharge rate on those is 600 mA. As you can see, 1.23A is WAY over the 600 mA MAX discharge rate. It's in fact 3.84C. I contacted again about the result of discharging those 10440 at this rate and he replied that they would die fast. Also, there is a comment from Newbie about discharging a Li-Ion cell at a too high rate:
https://www.candlepowerforums.com/posts/1258756&postcount=15
You can also find a discussion/review on the L0D on 10440 I had with another CPFer there:
http://candlepowerforums.com/vb/showthread.php?t=148412&page=1&pp=30
Based on that, I still like the way the Primary level with 10440 cells is the same as High with NiMH or as the L0P and I use often this brightness level. The new High with 10440 should then only be used for brief periods of time (probably < 1 minute or even less). As many noticed, the light becomes hot really fast. It takes 6 secs before I notice a warming and after 10 secs it is hot. At 2 minutes, the light is very uncomfortable to hold in hands.
What do you think of all this guys? I think sellers that advertise this light as being Li-Ion compatible should put a warning about using them in it!
Thanks
[EDIT]
Found on Lighthound website:
http://www.lighthound.com/index.asp?PageAction=VIEWPROD&ProdID=2501
NOTE: Input voltage is up to 3.6 volts, so the L0D will use the 10440 rechargeable 3.6 volt lithium battery with impressive results!
[/EDIT]
Primary: 0.42A
Low: 0.18A
High: 1.23A
Thanks
[EDIT]
[/EDIT]
