zeeexsixare
- Joined
- Dec 2, 2006
- Messages
- 113
To paraphrase what's being said, you can unscrew the head slightly using a rubber band on the fore part and the aft part of the head.
In more detail, look at the three o-ring slots towards the front of the head. The one closest to the front is actually a parting line for the two parts coming together. Carefully unscrew these two parts about 1/2 turn (you need some force to break the glue on the threads) and the dark ring disappears. You lose some lumens since the emitter's further from the base of the reflector, but it works perfectly. On the other hand, the lens is no longer firmly pressed up against the front of the head.
