now take a close look at where that red line BEGINS!!!.. WAY higher than the others... it's instaflash territory for the first minute or so!!!
3.0V rechargables are just not going to have the ideal characteristics for an incan lamp that was designed to be used with primaries...
you say they are 6V lamp assemblies, you are incorrect, in reality, they are more like 5V lamp assemblies that are being pushed to the limits at 6V and run reliably at around 5V... They have been designed this way on purpose because the manufactures of tactical lamp assemblies choose bulbs with the voltage sag of lithium primaries in mind. 3.0V RCR123 cells tend to be about 3.2-3.4V freshly charged and tend to deliver this (as shown in the graph above) for the first short while until the power is drained a bit.
this question keeps popping up... I'm going to keep offering the same recommendation: get a 17670 and a 3.7V lamp... It will be brighter and run longer than anything you can do with a pair of those 3.0V RCR123s... and if it is brightness you want. HO-9 from Lumensfactory and a pair of standard protected 3.7V RCR123s from AW.
It just seems meaningless to me to purchase yet another lamp assembly for this flashlight, which would more than likely render the other two useless.
When the P60s you try to drive with that setup burn out prematurely, it will seem much more meaningless to have to buy an entirely different set of rechargable batteries and charger to keep using your light. .. Do it the right way now.... see if you can sell your partially used P60 and or P61 over in BST, then use that cash to buy a lumensfactory or WE or G&P lamp for around $10-15.
also...I can darn near guarantee that there is no RCR3.0V anywhere that will light up your P61 worth a darn anyways... it'll be really really scorchingly bright for about 2 minutes, then fall on it's face.. each time you use the cells on the P61, you will do internal damage to the cells, which will lead to the possibility of catastrophic failure ("vent with flame").... (with a side of hydrofluoric acid).. or they will just totally die prematurely.. No matter what happens, you'll wish you had just abandoned the 6V lamps and moved on to the better combinations available before wasting the cash.
