Powering your flashlight with Candles?
gregw
Hong Kong
See the video here..
I don't have the necessary stuff on hand or else I'd try it out.. :) Looks almost unbelievable...
blahblahblah
California
WTF!
Can someone explain what I just saw?
If someone tries this, can you test to see the volts/amps coming from the leads?
BB
SF Bay Area
You did not ever see the underside of the candles or behind the candles after the cut... Just put a piece of foil inside the candle and set on table and run foil/conductor down behind the table.
Just a magic trick.
-Bill
Empath
Oregon
As demonstrated, cathode and anode is selected magically to fit the need. Magic has always been so undependable.
BB
SF Bay Area
Polarity is set by which candle is lit first... If you light both at the same time you get AC.
-Bill
Illum
Central Florida, USA
I cant even get the first part right....sticking a nail into a thick candle and not crack it i still cant do:ohgeez:
Brock said:
Nawww, to get AC your would have to blow them out and re-light really quickly ;)
blow out and relight 60 times a second?
:lolsign::lolsign::lolsign:
Led_Blind
Sydney, Australia
Re: Candle Powered - Is this for REAL !
For the life of me i cannot see what physics or chemistry is in play here that will allow this to work.
Anyone?
alantch
GMT +8
Evan, nice find. As illogical as it seems, maybe I'll give it a go myself some time.
DonShock
Belton Texas
Totally fake. Notice that each time he lights the second candle, his other hand goes under/behind the table where he obviously has the real switch. There is probably another set of wires running up inside the candles to supply the real power.
evanlocc
Malaysia
Really, i am not alone here !
What make me suspect most was the 3V output.
aljsk8
Wigan, UK
the problem is he lifts the candles and there is no visable wire - my guess is very thin wire that the guality of the video hides
