Hi everybody
I have fews question for you :
If i buy a L1D ce with battery Li-Ion 14500 rechargeable 3,6 volt and 750 mha protected..
1 - The power (lumens) of the L1D Ce in Turbo mode with 14500 cell 3,6 volt will be better than L2D CE with 2AA (3volts) (same Bulb, head and led, it's logic i think) ?
But the Battery capacity of the 14500 is low, with only 750 mah, it's a problem versus AA classic capacity ? bigs differences ?
2 - Same question for the LD2 CE, if i use two classic AA cells rechargeables (1,2 volt only by cell, vs 1,5 normal AA) the power with lumens will be different ?
what is the best compromise ?
thank you by advance
regards
regards
