I recently received my laser kits from DR_Lava' s group buy and was looking for a good host to place one in. I had an old amber CMG infinity that looked just right. I had previously designed a replacement driver board for another Infinity so that I could drive a Luxeon at 1 watt off a single cell. I designed it using a LTC3490 boost converter chip and still had about enough parts to make another one. I did not have a 3.3uH inductor so I used a 10uH with a lower current rating which worked out because I did not want to drive it at the full 350ma. I followed the speck sheets recommendation for running a red luxeon but I used a regular silican diode instead of a shotke in series with the light emitting diode. I found that with the poor choice of inductor it provides about 170ma to the laser which is probably a good conservative amount that will still provide impressive results. I drilled out the flashlight head and Acrylic Silver epoxied the laser module casing in.
It is very small has easy focus adjustment and should have rather stable power output of about 100mw.
I am able to light blackened matches almost instantly with the lens focused.
I am going to really like this tiny burner and I will have lots of fun with it.
