whc
Thought it would be "fun" to see if the head from LP-Mini's head with the nice deep OP-Type reflector would fit on L1D CE. And it is possible, used a Post-It that i folded 4 times, to fit the head on the L1D CE (the diameter of the head on LP-Mini is bigger).
This is just for fun, just to see how the L1D CE would work with an OP-Type reflector, that I would very much prefer when using the XR-E LED. The result is pretty good, almost no ring, and with better throw then with the original smooth Fenix reflector. The deepness of the LP-Mini's reflector gives the L1D CE overall a brighter output I think.
Here is some pictures:
Now to some beamshots, here you see the L1D CE with the LP-Mini's OP-Type reflector. All images is with Li-Ion 3.7v batteries, and the L1D CE is on Turbo mode. The white wall shots are from about 1 meter distance.
L1D CE with LP-Mini head, Li-Ion 3.7v
L1D CE with LP-Mini head, Li-Ion 3.7v, 2 stops underexposed
L1D CE with Stock smooth head/reflector, Li-Ion 3.7v
L1D CE with Stock smooth head/reflector, Li-Ion 3.7v, 2 stops underexposed
It is clear to see that the ring is as good as gone with the LP-Mini head, very nice, would wish that the L1D CE's beam looked like this with the stock reflector ...
