defusion
- Joined
- Feb 21, 2007
- Messages
- 459
Here's a list of things i want on my perfect flashlight, and am hoping someone out there knows just who makes it, or what i need to mod it together with existing parts.
- Normal size, i like my fenix L2D-CE, but it may be a bit longer and thicker (i dont want an very small one that you need to hold in your fingers, but it should be concealable enough using a belt holster, so no mag 2D and up size)
- Lots of blinding lumens + 2 more normal modes (500 lumen, 250 lumen, 50 lumen (and maybe an uber low output mode of around 5 lumen for reading))
or maybe even better, a stepless variable output.
- focusable beam (maglite-ish)
- rechargeable batteries (a proper solution, not 3x rechargeable 3v CR123A's, as they often can't handle the current for the high output very well)
- proper switch for modes and on/off, twist to change the output mode (mechanical memory), obvious dual-stage button, press half way for on (with an obvious increase in pressure needed to press trough), and press all the way for stay on, if on, press half way for temporary off and completely for switch off
- rugged design (should survive a 10feet drop repeatedly)
- flame resistant
- waterproof to about 30feet (10m)
Or is this near impossible, as i want to many features while still having a very rugged light? or am i, as my title says, unenlightened to all the possibilities?
- flame resistant
