Got a Cree star and did the swap out in a QIII. Pretty easy. Unsoldered the Lux and resoldered the cree. Drilled out the reflector. After I got everything back together the light did not turn on. I finally figured out what was wrong, the bottomside of the circuit board was not making good contact with the light body, so it was not getting a good ground. There was also some glue in some places that was also causing bad contact. It is working now, but it is dim. During troubleshooting of the problem I applied some power from a battery to see if I could figure things out. Big mistake. I saw smoke come from the boost board. I assume that I fried some part of the boost circuit, and now it is just running on direct drive. Anybody know where I can get a replacement for the QIII circuit board? I would rather stay with the original circuit and not get a new style boost board. Do any of the dealers sell replacement parts like this?
Thanks
Thanks
