Klarus
Page 1 of 2 12 LastLast
Results 1 to 30 of 36
Thread: 2D Mag goes 4*Seoul (w/ pics, now w/ beamshots)!
    Flashaholic* Nereus's Avatar
    Mar 2005
    Espoo, Finland, Northern Europe
    Default 2D Mag goes 4*Seoul (w/ pics, now w/ beamshots)!
    I just got finished a 2D mag mod with following specs:
    - 2D to 8AA battery holder
    - Battery tube inner diameter sanded 1mm larger (holy crap what a job! ) to accept those damned oversized Energizer 2500 mAh Nimhs.
    - Shark converter
    - 3 stage switch: 50 / 250 / 1000 mA
    - Runtimes 35 / 8 / 1,5 hours correspondingly
    - UCL lense
    - 4*Seoul P4 U bin leds
    - 4*McR20s reflectors
    - Works best with Nimhs, but alkalines can be used as well. With alks the runtime at high drops to 30 minutes but other runtimes remain the same.
    In case of emergency 2 D cells can be used as well. Low and medium level will work ok then, but you will not get full brightness at high.
    Here is general pic of the mod:
    That is what the business end looks like:
    Yet closer look on the business end. It was very hard to get the emitters centered because the reflector hole is much bigger than the led dome.
    Here you can see the current setting 3 stage switch. I left the original switch as it was for turning the light on/off. Watching carefully you can see a reflection of me and my camera...
    At high mode the light head gets quite warm, some 50C at room temperature. You can touch it but you don't want to hold it in your hand for a long time. This makes me think that 15W of heat is pretty much the upper limit that the Mag head can safely handle.
    Thanks for looking!
    -N
    My mods. Please post questions about my mods to the corresponding thread: like that all CPFers can get the info - thanks!
    Default Re: 2D Mag goes 4*Seoul (w/ pics)!
    Nice job!
    What did you use for a heatsink/mount for the emitters?
    Mar 2005
    Thanks! I used Modamags PTS2 heatsink, see this thread: http://candlepowerforums.com/vb/show....php?p=1266271 . I cut it down so that there is perfectly flat surface where you can install the leds. You can see this flat aluminium surface if you look between the reflectors.
    -N
    Nereus, as you have set the 3 stage switch with the shark?
    Flashaholic* cratz2's Avatar
    Apr 2003
    Central IN
    I guess I need to read up on the Shark. I didn't realize it had multi levels.
    Sometime this year, I'll be doing something similar but I'll probably do it in a 2C housing. 3 or 4 Crees. I deally, I'd like to be able to do about 20mA to each LED for low, 200 to each LED for medium and about 600 for high. The 1000ma would be cool for just generally being impressive, but I think at 600, it would put out adequate light and get that much more runtime.
    I'd probably use 2x18650 cells.
    My big question is, what is the spill beam like on the 50ma setting? Is it plenty for walking in rural/woody areas without attracting too much attention. My goal would be something about as bright as the SMJLED PR 'bulb'. I'd imagine 50ma to each SSC would be well beyond that though.
    "That's what makes SF so badass... we've got the best flashlights."
    Retired Administrator Norm's Avatar
    Jun 2006
    Australia
    I bet that thing is bright. I love those Seoul's. I very tempted to make a 2 C size mag with 3. Great job.
    Norm
    Aug 2006
    Cologne,"Rome of the North"
    ok,how does the switch work?what kind of switch is it?how is it implemented?
    greetings,alex
    Mar 2005
    Quote Originally Posted by boef800
    greetings,alex
    Here is a foto of the 3-stage switch:
    Here is a foto of the (waterproof) rubber cover:
    There is a tiny potentiometer on Shark with which you can adjust the current. It can be easily replaced with wire+resistors and with the switch you can choose which resistors are active, mimicking different positions of the current setting potentiometer. See this thread for good info on Shark: http://www.candlepowerforums.com/vb/...d.php?t=105492 .
    Thanks for positive feedback, guys!
    -N
    Mar 2005
    Quote Originally Posted by cratz2
    ...My big question is, what is the spill beam like on the 50ma setting? Is it plenty for walking in rural/woody areas without attracting too much attention. My goal would be something about as bright as the SMJLED PR 'bulb'. I'd imagine 50ma to each SSC would be well beyond that though.
    Originally I built this with 4*LuxIII u-bins and McR20 reflectors one year ago. At that time 50 mA was a very good low setting. You have it right: now with the Seouls the low mode is slightly too bright, some 20-30 mA might be ok. I was a bit lazy now and did not upgrade (downgrade?) the lowest current... I have built some mods with SMJLED PR bulb and I can assure you that 50 mA is way overkill if you are seeking for similar amount of lumens.
    One very interesting feature of the mod is the fact that when using alkalines the light goes to direct drive mode at low. This happens because under light load the voltage of an alkaline battery is higher than that of nimh's. I measured some 80 mA input (and output) current at low with fresh alks. And dd mode is pretty efficient...
    Let's see if I will be going to countryside next weekend. I could post some real world beamshots at different modes to give you an idea what the output looks like.
    -N
    Apr 2003
    Central IN
    You know we all love those beamshots!
    Why dont use a dial type potential meter. variable resistance
    Quote Originally Posted by Nereus
    -N
    Mar 2005
    Quote Originally Posted by snipinglight
    That came to my mind 1 year ago when I started this project. I wanted to have 3 fixed levels instead of infinite amount of levels so I used a switch. Like that you know exactly at what mode you are running the light and most importantly you know what kind of runtime to expect. With infinite levels it is much harder to know that - in the worst case situation you run out of electricity because you had no idea how many amps the light was pulling out of the batteries.
    -N
    Flashaholic* Icarus's Avatar
    Nov 2003
    Belgium
    Good job!
    I'm wondering how you could keep the reflectors centered.
    Mar 2005
    Quote Originally Posted by Icarus
    Good job!
    Thanks! I have a special trick up my sleeve to center the leds... I could post some pics on that part of the mod process too, so stay tuned for further info guys!
    -N
    Good job!
    Yes i'm curious about this i think you have used a plastic ring where it fit around the led and where the reflector sit.
    Flashaholic* tino_ale's Avatar
    Nov 2005
    Paris, France
    Thinking Re: 2D Mag goes 4*Seoul (w/ pics)!
    Nereus,
    Nice job!
    But I don't see how you can get 2 hours of runtime from 8AA Ni-MH @ 1000mA.
    If 15W goes to the LEDs (which seems just a little over rated considering the Led's forward voltage, I would say it is more 14W), and assuming the circuit is 85% efficient, that means the circuit taxes 16,47W from the batts.
    At this kind of current, an 8 AA ni-MH pack will give you at most 2500mAh if you choose Sanyo 2700. This is 24Wh.
    If I do the maths correctly, you will only have around 87min. And that is with out of the charger batts...
    If I change circuit efficiency to 90%, you should have 92mins. We are still half an hour from 2 hours.
    How can you get 120 min at this power???
    Bead Blasting McGizmos - PM disabled, email aoc.paypal (at) gmail.com
    Mar 2005
    Damn it, you have it correct! I must have confused this with some other mod... I will edit the original post - thanks for your comment!
    -N
    Nov 2005
    Paris, France
    It's true it's easy to get confused with these numbers... I made myself a little spreadsheet with Excel to calculate current draw and autonomy from number of leds, current to the leds, Vf of the leds, circuit efficiency, number of batts, voltage and capacity...
    Very usefull!
    Mar 2005
    It is time for a beamshot competition! Standard 2D Mag on the right, 2D Mag seoul on the left:
    First one indoor beamshot. I guess that I do not need to tell you which one is the Mag 2D seoul @ high?
    Mag 2D seoul @ high and std 2D Mag side by side:
    Mag 2D seoul @ high, the distance to the shed is some 200 m (checked with a map):
    A bit closer distance this time, Mag 2D Seoul @ high. Distance to the trees on the right and left is some 5m. Distance to the trees in the middle of the pic is some 30m.
    The same view, Mag 2D Seoul @ mid:
    The same view, Mag 2D Seoul @ low:
    The last photo shows that there is usable side spill and throw (up to 30m) even at low - it should answer your question, Cratz2. Generally the Mag 2D seoul has "floodish throw" beam: generous side spill and good throw and the light is good at distances up to 250m, IMO. But if you want more throw you should use bigger reflectors.
    -N
    Default Re: 2D Mag goes 4*Seoul (w/ pics, now w/ beamshots)!
    ok in your opinion, whats brighter? the quad u bin luxeons or the quad seouls?
    im contemplating my quad u bin mag and dont know which way to go, cree or seoul
    "You...Light Up My Life...."
    Mar 2005
    Seoul is clearly brighter, no doubt. BTW, nice avatar!
    -N
    Good job!
    It's a secret?
    Mar 2005
    No it is not... I am making step by step pictured guidance how I made this mod: http://www.candlepowerforums.com/vb/...d.php?t=153982 . I used the same technique with it. So, it is a matter of days that you will see how I did it.
    -N
    Flashaholic gammaray1965's Avatar
    Jan 2007
    U.S.A.
    Nereus, What do you think the lumens output would be for this 2-D mod?
    And GOD said, Let there be Light,and there was Light. He who is without The Light, Lives in Darkness.
    Flashaholic* Atomic_Chicken's Avatar
    Jun 2005
    The Atomic Coop
    Greetings!
    Nice job! Where was the switch and cover obtained? I have a project i'd like to use that in...
    Best wishes,
    Bawko
    Support your local chicken
    The Ultimate Light: Surefire A2 Aviator - Thread Index!
    Announcing: Aviatrix mods for Surefire A2 Aviators!
    New product: World's finest keychain glow fobs!
    Mar 2005
    Thanks! I have heard about "up to 240 lumens at 1A" marketing mambo jambo for the u-bin P4 led... I think some 200 lumens per emitter at 1A is closer to the thruth, so that is 800 bulb lumens. Throw in to the equation 30% optics losses (that is general CPF consensus) and we are talking about 560 torch lumens.
    I bought the switch and cover in a finnish electronics store called Yleiselektroniikka... But that is a very common switch, you should find it in many international electronics stores. It's produced by Apem.
    -N
    Mar 2005
    Okay guys, it is time to reveal the secret - have a look on this thread http://www.candlepowerforums.com/vb/...d.php?t=156336 for a description about how I centered the leds.
    -N
    Feb 2003
    Northwest Indiana
    Nice mod Nereus! Are you satisfied with the switch and cover? If so, do you have the part numbers/manufacturer so I can locate and purchase as well?
    Thanks!
    Charlie
    Li-ON Heart #126, VIP!!,Blaster III, Pal Light, ARC LSL, lots of non led!
    Mar 2005
    Quote Originally Posted by Zman
    Thanks!
    Charlie
    Thanks! That's Apem 5000 series three stage (on-on-on) double pole 5644 switch. Here is the Apem catalog page where you can find it: http://www.apem.fr/pdf/uk/section_a/...-structure.pdf . The switch cover is U1231 neoprene sealing boot, see this page of Apem catalog: http://www.apem.fr/pdf/uk/section_h/01-Boots-A.pdf . And yes, I have been satisfied with the switch and the cover - no problems so far.
    If you are using alkalines you might want to use similar kind on-on-mom Apem 5644 switch. Like that the high mode would be momentary on only which is good because the runtime @ high would be quite short with alkalines.
    -N
    oh last thing, im usung some So2Xa reflectors, will these fit the seoul LED as well?
