Imalent
Results 1 to 20 of 20
Thread: Princeton Tec Apex Seoul SSC P4 mod with beamshots
    Flashaholic luminari's Avatar
    May 2005
    Nevada
    Default Princeton Tec Apex Seoul SSC P4 mod with beamshots
    So I decided to open up my Princeton Tec Apex and give it a nice upgrade. This is a u-bin P4 bare emitter bought from a CPF group buy.
    I don't plan on writing a detailed mod thread as there are better writers on CPF who have already done so for the Apex, but I would say the mod is not too difficult: you need to unscrew the housing (make sure you don't lose that o-ring) and pull the old emitter out.
    The results were quite bright, though the optics in the Apex continue to disappoint with their ringy spill beams. I may replace it with a reflector at some point. The hotspot was huge, though, so I guess that reduces the problem a bit.
    I have some DealExtreme HASTO 3W headlamps in the mail that I plan on modding and giving as gifts, but the PT Apex's good electronics, reliable construction and, most importantly, excellent heatsink (external heatsinks are great, Petzl and Black Diamond!) has made me want to kick it up a notch.
    The heatsink indeed got a workout as it got warm to the touch when running on high. I guess that means the thermal compound on the heatsink is doing its job.
    Apex stock high
    Apex stock low
    Apex with SSC P4 high
    Apex with SSC low
    I'm hoping to test this on two 14500 lithium ions due to the great weight savings, but their combined 8.4 volt peak voltage gave me pause. Does anyone know the Apex's maximum rated input voltage? I know it can run on lithium primary AA's, but four of those still fall short of 8.4 volts.
    Flashaholic* jar3ds's Avatar
    Sep 2005
    USA
    Default Re: Princeton Tec Apex Seoul SSC P4 mod with beamshots
    you can run two lithium-ions in the apex... i can't remember the exact max voltage but i'm sure it works just fine....
    i'm interested in modding the apex 5mm LEDs to red LEDs... but i'm not sure which red leds would be the best... what do you think would be the best red LED's to mod the apex with?
    Thanks and thanks for sharing!
    Quote Originally Posted by jar3ds
    I had the same idea... I found a 20,000 MCD red 5mm LED...Vf 50ma...
    http://www.jaycar.com.au/products_uploaded/ZD-1790.pdf
    I guess it depends on the current output to the 5mm LEDs in the apex...
    I also found a 5mm LED that could take 1A... but no use in the apex...
    you know I was also thinking of putting 2 RED leds on the flat bits on the sides of the EOS...
    keep up the great work guys...
    Ktronik
    *Flashaholic* mdocod's Avatar
    Nov 2005
    COLORado spRINGs
    You could rewire the battery box to run a 2P2S configuration of 4 14500s.
    basically, it would be a 7.4V 1500mah pack...
    11.1 watt hours or so....
    not bad compared to NIMH which would be 4.8V @~2500mah 12 watt/hours...
    the lack of self discharge would probably mean that by the time you use the cell, you'd have more power available in the li-ions..
    -Eric
    May 2005
    Nevada
    Hmm, I don't know much about the red 5mm LED world, but that got me thinking... the Apex's 5mm LEDs are heavily driven. Does anyone know at what level?
    Is it possible to swap them out for high-flux LEDs like the SSC P4 or the Cree? I know they won't be driven very hard, but imagine the spill and color quality! That would be awesome! I guess the question is if they would even light up at that low drive/voltage level.
    Quote Originally Posted by luminari
    In theory, the white 5mm LED will be driven @ around 3.2v-3.6v so the voltage would be the same... & yes it would be more efficient to run a lightly driven led than a heavily driven one.... in fact most modern leds are most efficient @ 100ma... so good idea... I know cree has a half watt led that is real small...
    ktronik
    I just did a PT Apex SSC mod today.
    The best reflector for the mod is the McR-20 Seoul. You need to remove a few tenths of a mm off the rim, and afterwards it fills most of the clear plastic bezel and looks almost stock.
    Toshi
    Sep 2005
    USA
    Quote Originally Posted by TMorita
    Toshi
    excellent! I have a question though... where did you take the mm off of? you say rim... but does that mean the base (where the LED is) of the reflector or the top (big end)?
    Quote Originally Posted by ktronik
    Ktronik
    ktronik, how do the LEDs you mention compare in terms of output? Would they be similar to the nichia 2x white leds only in red? As far as total output? How would their beam profiles line up? Thanks!
    for some reason red is always brighter in the same type of led...ex for a lux3 the red puts out more lumens than the same lux3 in white... beam profiles should be the same... but someone smarter should chime in and give you a better answer...
    I guess red is easier to make than white...red-orange is brighter again...
    ktronik
    ....... for some reason red has a lower forward voltage, the ones in your link are only 2.1v so they may go
    and the lux 111 red/orange output spec is at 1400ma
    http://www.lumileds.com/pdfs/DS45.PDF
    Sep 2005
    USA
    Quote Originally Posted by HEY HEY ITS HENDO
    sigh.... still looking for the best red 5mm leds to put into an apex
    would anyone be interested in adding a seoul ssc p4 to my apex for me? i'd pay you a little for your trouble.
    Fenix 1LP, P2D CE, 1LP Millermod Ed., Lumapower M3, SL Propoly AA, Maglite 2aa LED, LEDBeam, Dorcy Super 1 Watt 3D, and Princeton Tec Apex, EOS, and Yukon HL.
    Just put a seoul p4 in my apex and it was quite easy. What reflector is everyone using? The stock one is good but I want a tighter beam and longer spot. Has anyone tried a IMS 20 mm? Also, I want to switch the white 5mm led's to red ones. Anyone try this yet?
    Aug 2001
    VA
    Just put a SSC P4 in today. The results are great. I tried a few reflectors I had lying around and liked the IMS17 the best. I had to trim the IMS legs and the little alignment pins next to the LED, then dab a bit of glue to hold it in place. The IMS20 is too tall and requires removing some material and I never can do that without screwing up the reflector.
    you can see the spill angles line up.
    The new P4 in place:
    Light is the activity of what is transparent - Aristotle
    Mar 2005
    Northern NJ, USA
    CaveDave - how is the beam w the reflector? I would consider this mod if I could get a floodier beam.
    How good do I have to be at soldering for this mod? I've replaced Lux stars w Cree stars, but this looks like the leads on the LED have to be soldered - I don't know if I can be that precise.
    Aug 2001
    VA
    The IMS beam is pretty floody. The hotspot is about the same as the original optic but the spill is so much brighter and even. I added some writewright to smooth it out a bit more (actually it was left over from the optic). I think its just about perfect for caving and hiking now. It has a real smooth transition from spot to spill and lights up a wide area evenly. For a real floody beam you could use the P4 textured reflector that PhotonFantastic sells. I tried it but it was too floody.
    The only problem with this mod is the 5mm LEDs are now obsolete. All blue and artifacty, the main beam is so good they are useless. I would like to have a couple more lower levels though on the main beam. I think low is putting out almost 50 lumen's.
    Quote Originally Posted by cave dave
    Hi dave, nice work and thanks for the pics .........
    re. the (obsolete) 5mm LEDs,
    ..... would it be feasible to run them at the same time as well as the p4, and thus, would you still, consider them as "obsolete"?,
    if, it is possible to run them at the same time, then you could maybe consider them as a bonus instead of .......
    ktronik
    red and orange are the longest wavelengths ( lowest frequencies) of visible light, and have the lowest energy requirements to produce, as defined by E = hf, where E is the energy of the photon in electron volts, h is Planck's constant and f is the frequency of the photon.
    I am not commenting on the internal efficiency of the LED, just noting that the wavelengths you mentioned are the cheapest to produce, photon for photon.
    Flashaholic* Changchung's Avatar
    Oct 2005
    Where the night is too short...
    Quote Originally Posted by jar3ds View Post
    Hi, I find some time ago the brightest red Led like I never saw
    I buy from here;
    http://www.hyledchina.com/led-lamps/led-5mm.html
    5034R1C-BUA-D AlGaInP Red 620-635 Water Clear 1.9 2.5 10000 15000 15º
    Trust me, is realy bright...
    If you want I can record a video for you...
    Zebralight Spark Princeton Inova Petzl Maglite Bushnell 4 XM-L MagMod and a lot of Cree XM-L Lights Nitecore i4 Intellicharger Intl-outdoor 3400 Panasonic 3100 Bare and protected Samsung 3000 Sanyo 2600
    Please, respect the planet, dont kill animals...
    Flashaholic* grnamin's Avatar
    Nov 2000
    Plano, Texas
    Trimmed down McR20 reflector:
    -Greg
