MacTech
I went into Sears tonight to pick up a couple of their 3AAA Luxeon "Endurable" lights so i could harvest the PR base Luxeon bulb, but Sears (actually Dorcy, i think) has saved me the time....
they're now selling the LED bulbs as a stock item on their own, part # 34-93044, $14.95
here's what they claim;
"Variable Power, produces from 37 to 50 Lumens depending on your flashlight"
the bulb can handle 1.5 to 8V, they have a basic grid on the back with the bulb stats, i'll post their lumen claims here...
Voltage Estimated lumens
1.5V 24
3.0V 37
4.5V 45
6.0V 47
8.0V 50
I'm thinking that it's probably got a basic buck-boost circuit inside, maybe just a buck....
they also *claim* that the bulb can be used in a 6V lantern, I highly doubt this, as most lanterns are polarity reversed from normal flashlights, some flashlights also are polarity reversed, the incan Eveready Hard Case and the Ray-O-Vac swivel head, i have a R-O-V swivelhead (old style with faceted reflector), and if i want to use my MJLED PR in it, i have to put the batteries in backwards to get it to light, when i put the Sears bulb in the R-O-V Swivel with the positive tip of the batteries facing the head of the flashlight, no light, if i put the batteries in with the positive tip facing the tailcap, the Sears bulb lights up
so i'd hazard a guess that lanterns *DO NOT* work with this bulb, rather stupid of them to put that claim right on the front of the package
I figured it was worth a try so i picked up a pair, put one in my ROV swivel, put the batteries in backwards, and lit it up.....
indoors it throws a nice clean white spot, the ROV Swivel reflector seems optomized more for throw than for a smooth beam, there are a couple of faint corona rings around the hotspot, but that's more a function of the reflector than the bulb
outdoors on a moonlit night, it's easily overcome by ambient moonlight, it barely illuminates the haybarn, i'd imagine it'd perform better under a cloudy evening sky or moonless night
I also tried it in a cheapo Eveready 2AA Industrial, a little more floody, but strangely enough, it wasn't much brighter than the MJLED PR
I then grabbed the mediocre Snakelight, and dropped the bulb in.....
This one actually works well in the Snakelight, a nice, even flood, floor to ceiling, not too bright, but not dim either....
Then i had a brainstorm.....
i took my spare 2C to 3-123a spacer tube, a dummy 123a slug and 2 123a batteries and dropped them in
Ahh, MUCH better, a nice *bright* flood, and seems to run reasonably cool as well
not a bad little upgrade bulb, and no more need to purchase Endurable 3AAA's just to harvest the bulbs
1.5V 24
3.0V 37
4.5V 45
6.0V 47
8.0V 50
