Soft Shell: Windstopper, Windbloc, Schoeller, Polartech Power Shield, Wind Fleece & polartec type fabrics (Most of these are a variant of polar fleece)
Most soft shells will provide 1) Warmth 2) Wind resistance 3) Water Repellent eg a drizzle for a short period
And to confuse the situation even more there are different weights in these fabrics
Hard Shells: Gore-tex, Sympatex, Entrant, eVENT, Ultrex, Laminate, Polyurethane Coated fabrics, (Most of these are shell type garments with no liner)
Hard shells are designed for extreme weather eg storms and usually are made to go over your insulating garments.
For most people a combination of a soft and a hard shell works well, while the weather is just cold & windy you can wear a soft shell then when the wet stuff hits the dry stuff you can put on your hard shell outer garment/s.
Or if the weather is warmer but wet then you could just wear the hard shell with out the soft shell.
But for some people they like the convenience of only carrying the one jacket so they get a lined/insulated garment.
The Hard/Soft Shell distinction is mainly for the tramping/mountaineering/camping areas where you want a bit of versatility in your clothing options without having to carry a huge amount.
AtomSphere said:
I still don't know what each one looks or feels like. I yahoo'd and goggled it but the pictures seems the same except they say soft-shell is a more comfortable and preferred clothing.
I recently knew there were products that can help restore water resistance in a jacket and I am not sure if one of my
Helly Hansen Codex, which is stated to be 100% Polyester, is a soft shell or a hard shell.
I am afraid to purchase the wrong product for water resistance restoration.
The jacket the link points to would be a lighter weight soft shell which you would most probably use end of spring, end of summer, beginning of autumn when the temps are starting to go down in the evenings.
For most brands you should be able to find an email address for and ask them what product they recommend for cleaning then rewater proofing.
You might want to look at
Nikwax which sells different wash / waterproofing solutions for most clothing.
