berto
dealextreme has twiste 123 lights for $6 bucks shipped. and hopefully a cree star will fit right in there.
Hmm. That kills my idea about using the Cree Elly reflectors. It looked similar to me, but you'd know better as you have it or one like it. I still think a U-bin Seoul emitter coudln't possibly hurt it though Have you done any current measuring tests on it? It's probably just resistored, and if so have you checked it with an Ohmmeter?Nake said:I have one of those and no way a star will fit without considerable cutting. A star is 20mm across, the emitter board in that light is 15mm, maybe one of those mini stars. Reflector is smaller than the Elly too. Unless I have a different one. Everything is the same as in the picture. It's pretty tinney too. I bought it to mod, but thought not worth it.
Hmm. The resistor value shouldn't be too hard to determine -- you can place one contact of the Ohmmeter on the (+) on the LED star, and another on the (+) battery contact (assuming positive goes "facing in"). Current may be tougher as you say though, but if we know the resistor value, that should be easy to guess/estimate without reading current directly. Based on a runtime of an hour, it's probably pulling about 3W on average -- as that would be 800mA * 3.7V. Since the battery is 800 mAh that gives a runtime of one hour. That light could be awesome with a Seoul LED.Nake said:If it ain't got a tailcap, I don't know how to check current. I'm thinking it's direct drive, it takes a 4V RCR123 with no problem, just gets a little warm.
2xTrinity said:Hmm. The resistor value shouldn't be too hard to determine -- you can place one contact of the Ohmmeter on the (+) on the LED star, and another on the (+) battery contact (assuming positive goes "facing in"). Current may be tougher as you say though, but if we know the resistor value, that should be easy to guess/estimate without reading current directly. Based on a runtime of an hour, it's probably pulling about 3W on average -- as that would be 800mA * 3.7V. Since the battery is 800 mAh that gives a runtime of one hour. That light could be awesome with a Seoul LED.
NetKidz said:Not sure if this one could fit?
http://www.kaidomain.com/WEBUI/ProductDetail.aspx?TranID=1340
7.3 would tend to put the power consumption at around 300mA/1W if this is direct drive -- based on the fact that 7 Ohm resistance is what the two level mode lights at DX all use for "low".I put the red lead from the MM on the batt + and the black on the emitter + and got 7.3. If I reverse the leads the numbers are all over the place.
Hmm.. the driver is probably voltage regulated. I just did a test right now hooking up a freshly charged CR123 to a MXDL LED -- at 4.2V it was only pushing 500 mA. A Cree would probably draw in excess of 1.5A in the same conditons, so a "safe" voltage for the MXDL may in fact be overdriving the Cree, and with such a small light, it could get HOT fast. That's too bad, perhaps adding a bit of resistance in series or something would fix it. I have one on the way from an order at Kaidomain a couple weeks ago that might be at the post office monday, so I will report if I find anything out.kanarie said:Those 3W MXDL CR123 light aren't good candidates for modding.
The cicuit board almost melted after putting in a a Cree and a CR123 3,6V.
Had to put it out in seconds
berto said:of course as soon as I order some of these they will come out with a cree version with an aluminum reflector.
