DJ Q
Is there a clickie for the magled aa? the minimag aa has a different thread, so the nitize per se won't fit.
Streamer said:
jram67 said:...but I use an oversized o-ring. Replaced the head o-ring with a fatter one from the hardware store and made sure to remove all the lube from inside the head. The dry, oversized o-ring keeps the head from turning. I have to use 2 hands and a rubber jar opening aide in order to turn the head. it definately will not accidentally move on its own.
uk_caver said:That's a really great idea.
I'd been wondering about ways to fix the focus on my homemade LED conversion, and your method sounds perfect, especially as the old O ring was getting a little worn.
frasera said:is the terralux clicky like the niteize? with momentary partial push? is it less loosy goosy than the niteize?
I scrounged a thick O-ring off a friend at the weekend, and it's great.jram67 said:Yeah, I've been using mine on the job with the oversized o-ring for a couple of months now and it has not moved at all. The terralux switch is going strong too, no problems to date.
