SF 6P old model --> tailcap?
yellow
Baden.at
Hy together,
I have an old 6P here, the model witt the round body.
My original Tailcap is getting wobby and I want a new one, with a klickie at best.
Now Lighthound sells a Z41 tailcap, but I can not find any info on the SF hompage.
Is this a clickie switch?
Will it fit my old 6P?
What model do I have to get, if this one is not the suitable one?
and one last question: are SFs clickie caps positive or negative?
Intended use is a Flupic mod.
kelmo
Sacramento
Yo yellow,
Instead of getting a new switch try this first. There is a notch below the stock O-ring. Install a O-ring in this notch and it will tighten up the switch and reduce the wobble. I did this with my 6P and 9Ps.
kelmo
Flash_Gordon
NC USA
If you want to add a clickie to your 6P you will need a Z59 or Z49. The Z59 is more compact and IMO better fits the look and size of the 6P. The Z49 is a heavier tailcap with a rubber shroud.
Mark
