FlashCrazy
Update: (9-10-07) Several lights are available for immediate shipment.
If you would like to order one, just send me a private message here CPF, or you can email me at [email protected]
Please see info about international shipping below.
This light has been labeled a "must have" for flashaholics...not by me, but by some happy customers. I do happen to agree, though! See for yourself...check out posts #173, 222, 271, 373, and 414.
Here's a list of other positive testimonials:
#36, 45, 70, 106, 108, 110, 113, 125, 143, 155, 168, 170, 171, 177, 181, 190, 217, 226, 236, 252, 261, 281, 286, 314, 318 340, 370, 372, 436, 438, 442, 444, and 445. Or you can save time by just ordering one to see for yourself!
Here's a list of the unsatisfied customers:
0. Yep, that's right...0!
I've modded and sold 50+ of these, and everyone has been happy with theirs! One person did return his because he didn't like the fit of it in his hand, but he did like the performance. I chalk that up to personal preference, rather than dissatisfaction.
Coast Focusing Lensers (Hokus Fokus) professionally upgraded with SSC P4 LEDs, SWO white tint. Quality original P4 LEDs from original packaging used...no questionable "off-shore" varieties.
These lights are already amazing, but with the addition of the Seoul P4, they're absolutely incredible!! Others have done this mod here too, and are blown away by the results. One of the great features of this light is that it has a TRUE momentary-on, tactical style switch. This light in stock form already has one of the brightest, most powerful beams for the money. With the Seoul P4, it blows away just about anything in it's class. According to SSC's spec sheet, the P4 can put out up to 240 lumens at 1000 mA. After lens losses, I'm conservatively guessing that these put out 150 to 170 "real" lumens out the front.
The lights are absoulutely brand new, but will not come with the original packaging. They will come with the original holster and a fresh set of alkaline batteries. The original lanyard is also not included, however, it WILL come with an even better, more heavy-duty lanyard. These lights sell like hot-cakes at Lowes for $49.95 plus tax, with the stock emitter. For a little more, you can have one that's twice as impressive!! I have many lights, and can honestly say that this is my favorite. It's the one that stays on the night stand, and is the only one I grab for "Did you hear that noise?" duties.
The price will be $69, shipping included! Sales to the U.S. only. Paypal only.
For International shipments, CPF member "Unforgiven" offers a small-package forwarding service for a small fee. Details can be found in his thread: http://www.cpfmarketplace.com/mp/showthread.php?t=141638
These will be periodically available as supply permits. Please refer to top of this thread for updates on availability.
Thanks!!
Here's part of the info sheet that I include with each light....I figured I should post it here as well.
Use only alkaline or Nickel Metal Hydride (NiMH) AAA batteries. Do not use Lithium rechargeable AAA's as their voltage is too high and will destroy the LED and can pose a fire hazard. Non-rechargeable Lithium batteries such as Energizer E2 Lithium drive the light a bit too hard and are not recommended.
Okay, with that out of the way, I'd like to make a few points about the light. NiMH rechargeable batteries work best in this light because they are able to maintain voltage very well under load. Using these, you should get 45 minutes to an hour of near full brightness, then the output will quickly dim. Alkaline batteries work fine, but they will sag in voltage in just a few minutes of operation, resulting in less than maximum light output. For intermittent use, it's not that noticeable.
The Seoul P4 LED used in the conversion has a different beam pattern than the original Luxeon LED. The good part is that the beam is a bit wider than the Luxeon and at the same time, brighter. The bad part of this is that the Seoul doesn't work as flawlessly with the optics in the flashlight compared to the Luxeon. This is only a concern for those who like to "white wall hunt". I shine all of my lights on the walls inside my house all the time, so I do my fair share of this too…as I suspect most "flashaholics" do. You'll notice a couple of prism type reflections and a faint yellow ring at the edge of the beam. The yellow is a reflection from the LED's phosphor base. Typical reflectors are designed to minimize this. I don't mean to scare you with this info, just want to let you know that it's due to the different beam pattern of the Seoul LED. When you actually use the light outdoors, none of that will be noticeable…you'll just say "wow, this thing is bright!"
Here are some pictures of the light and its construction...taken on 7-12-07. The last picture shows the Seoul Semiconductors Z-Power P4 LED (SSC P4) mounted.
SSC P4 installed
Here are some beamshots of a stock Focusing Lenser, and my SSC P4 modded version. Distance to the shed is about 50 feet. Both lights were using Eneloop NiMH cells. Enjoy!
The white shed probably isn't the best subject, since any extra brightness gets washed out. You can see the difference better if you look at the grass and foliage that's at the edge of the beams. At some point I'll get some beamshots taken at longer distances...longer distances are where the difference really shows. Remember, the Focusing Lenser in stock form is a great light to begin with!
More beamshots, from Lite_me, are in post #268. His shots are great! You can click on them to enlarge, too!
Stock, Narrow focus
SSC Modded, Narrow focus
Stock, Wide focus
SSC Modded, Wide focus
__________________
Thanks!!
SSC P4 installed
Stock, Narrow focus
Stock, Wide focus
__________________
