chanamasala
Fatman, three SVO tint U-bin SSC leds, cut down tri-led reflector from a cheap flashlight, and a custom heatsink. Thermally idiotic I suppose but I didn't mind if it came out well and worked okay for 10 minutes at a time.
Too bad it is pretty cruddy. I tried to center the leds to no avail. Puts out an ugly flood beam. 18650 would need a spring on the Fatman. Using two R123As right now. You just can't be sloppy anywhere it shows you. Dang.
