Yoda4561
I've read alot about surefire clickies failing on occasion, didn't think much of it till mine died after less than a month. It worked fine when brand new, then over the next couple weeks began feeling "odd", sorta mushy like something inside wasn't fitted right. One day at work it just finally got stuck and wouldn't move from the on position unless struck sharply against something.
I was about to call it in to surefire but after visually inspecting it I decided to try a bit of oil in the switch mechanism. In went the FP-10 and out came a switch that operated better than new. I decided that probably wasn't the best lubricant for this application so I went home and flushed it with contact cleaner, and applied some caig progold (made for electronic contacts and switches), the carrier made it stick like it was dry but once that evaporated it's been working fine and has been ever since.
So if your clicky gets stuck and doesn't want to work I'd suggest trying an electronics lubricant or carefully applied light oil before bothering surefire about it.
