wakibaki
FYI
OK in order to understand this beamshot you need to know: -
The wall is not neutral white it is a pinkish coloured plaster common here in the UK.
The torch overall diameter is virtually identical to the P1D but might be capable of losing a little (1mm?) wall thickness.
The P1D-CE is running in normal (middle range or startup) mode.
The aspheric torch is direct driven by 3 LR44 button cells at about 90mA with no dropper resistor. There is no supplementary reflector.
The torches are obviously both level with the camera, the distance is about 8 feet and this is close to the distance at which the aspheric is focussed.
I've only built an experimental head so far...
w
w
