For those who have followed the LS through developement, you'll remember that one of the reasons the design was delayed and the costs went up was because of the difficulty in waterproofing the lens.
After over a month of development and testing on the lens assembly to address this very issue of waterproofing, we finally got a design to be waterproof. In one test we left a unit at the bottom of a 9 foot pool for one hour. We also performed other tests. Looks like we should have done more testing because a good precentage of the units are still not resisting water- even with the design changes.
The "first" will have the same problem. Rather than delay further production, we will remove the water proofing claim from our website for now and fix it in later versions. For those who ordered this light based on it's water resistance, we will refund your money.
They seem to leak around the lens or the bezel thread. We really went overboard trying to fix this and it is going to require a major redesign. Most of you may not remember how much time and effort we put into the waterproofing system. We designed a whole lens management assembly with 4 types of expoy to seal the lens. We will eventuall get it solved for good, its not going down without a big fight though.
For now, keep the unit from immersion. Splashes are ok. If the lens does get fogged up, bake it in an oven set to 120 degrees fareinheit for about an hour. Not too hot or you might melt the lens. Some fogging may leave deposits on the lens so it is best to just keep it out of the pool, lake, toilet, etc.
The new design will take awhile, we have been working on it for some time already. It is a costly and involved design and does other things beside improve the water proofing system.
Peter Gransee
President
Arc Flashlight
