Sold/Expired FS: modified SF E1L w/ SSC P4 and McR20-S ***SOLD***
fnmag
Desert Southwest
Re: FS: modified SF E1L w/ SSC P4 and McR20-S
The E1L is a great little light, coupled with an SSC P4 and you've got a winner. Good luck with your sale.
T4R06
Rocky Hill, CT
note that i tested this on water and still waterproof. i did some modifications inside by putting o-ring inside actually its a GID ring :D
T4R06
Rocky Hill, CT
time to break, i will check this thread after 3hrs
remember, 1st who take it gets the light
time to watch passion of the christ
Turt
Anaheim, CA
what kind of estimated lumens will this set up produce?
T4R06
Rocky Hill, CT
@turt - i dont have luxmeter, but definitely it was more brighter and the runtime on single R123 is 40min. i dont know the runtime on primary. maybe double of R123
carbine15
Slaughter, WA
I have mine that I just modded exactly like this one and it's still making usable light from a primary after being on for 62 hours!!!... Very efficient little bugger. How did you keep the McR-20 centered over the emitter? (I know how I did it.. I'm just quizing you).
T4R06
Rocky Hill, CT
@carbine - very good question, same setup. but i replace the rubber into much thicker able not move the McR and keep tight and holding its place.
Turt
Anaheim, CA
I'll take it! and is this safe to run on 2 primary cells?
DaFABRICATA
Michigan
Nice catch!!! You WILL NOT BE LET DOWN!!!
I've got the same set-up and I am just blown away by the beam quality, and the run times will amaze you!
Enjoy!
nakahoshi
Dulles VA
Up to 9V, this is an awesome setup, Ive been EDC'ing this for weeks.
