Ultrafire C5 ( 2 x 2AA or 1 x CR123 or 1 x 16340)
C
calvinmo28
Guest
Specifications :
  • Ultrafire Name : C5
  • Battery 1 x 16340 , 2 x 2AA , 1 X CR123A
  • LED : Cree P4 XR-E
  • orange-peel aluminum reflector cup
  • Glass lens
  • Switch type: 1-mode
  • Accepted voltage input 1.2V - 3.7V
  • one extension for change to 2 X AA normal battery
  • Two type for 1 X 16340 Or use 2 X 2AA.
9volt
WI
Looks interesting. Where'd you get it?
9volt
WI
And before someone else says this - All your base are belong to us.
SQ40
The C5 with with the 1xCR123A Interests me most, What kind of Switch does it have (I See 1-Mode, is it Normal or Reverse Clicky)?
x2x3x2
Banned
Sounds nice, i think there was an earlier UltraFire product with the same CR123/2AA setup using a Lux too.
The images seem to be broken, perhaps try uploading to an image host instead of hot-linking?
kanarie
Think it is time for Ultrafire to put some intelligence in its flashlights. ...
hi/low/off as a minimum
PhantomPhoton
NV
:hahaha:
Ultrafire and a forward clickie???
Surely you don't want hell to freeze over and pigs fly.
I'm sure DX will have this soon enough, but um... what happened to the Ultrafire C4 then? Or is shipping products internationally with the label of "C4" a no-no?
:lolsign:
C
calvinmo28
Guest
The Ultrafire is no C4, because speaking '4' is mean dead.. In china '4' is not a luck number...
U Know.....
PhantomPhoton said:
:hahaha:
:lolsign:
SQ40
Agreed.
We need this with a hi/low/off normal clicky and we need it for under $25!
SQ40
Is it just me, or from the Pictures on Kai, there is no tailcap Switch?
