Turbo DV8
I have noticed that nearly all my headlamps use a Luxeon star. I am thinking of swapping them with SSC LED's. I know that one advantage of SSC or Cree over Lux is in efficiency; they can run either brighter with the same draw, or same brightness with extended battery life, or any mix in between. My question is, if I just swap out the star for an SSC star, without getting into power supply headaches, is there any way to know if my light will be brighter with less runtime, or equivalent brightness with greater runtime, or some middle-of-the-road compromise? Brighter would be my reason for the swap (so I can then diffuse the spill with GLAD Press'n Seal without compromising throw) but then I have concerns that my 3AAA headlamps would still offer useable runtime if the SSC efficiency advantage goes all toward brightness. My 3AA headlamp I think would give decent runtime in that case. From the SSC star swaps I have done on my Elektrolumens 2D Blaster and XM-3, I have seen both a nominal increase in current draw (reduced runtime) combined with increased brightness. Is there any rule of thumb which dictates what one will see from such a swap if one does not **** with the power supply, or does it depend on the type of power supply regulation, if any? Thanks.
