Handlobraesing
Banned
- Joined
- Feb 14, 2006
- Messages
- 2,724
What high power (Luxeon 1W or higher) flashlights commonly used offers active overheat protection?
[Add: quick summary of test result]
Tests I conducted:
Minimag 2AA LED: body temp stopped climbing at 51°C
River Rock K2 headlamp: appears to lack protection. Plastic parts melted, heatsink reached 170°C
Streamlight 4AA Luxeon's LED module: stabilized at 82°C measured at interior of the integral aluminum reflector. Module is kept inside the body and it is not direclty exposed to the user. Tested with 5.1v regulated power supply and blankets covering the module: Stabilized at 82°C
Other's result:
Fenix L2T by The_LED_museum reported entire body became too hot to touch and his IR thermometer reported 68°C, which is higher than the boiling point of methanol and hot enough to cause a burn to the user.
Full size Mag LED 2D: Newbie's graph in threads shows the module, which is covered from direct access from the user while in use stabilized at around 72°C
All these tests were of course, at room temperature. A flashlight should be able to handle usage in every one of their modes at any reasonably encoutered environmental condition without safety hazards or self-damage.
Original thread:
The Mag LED series definitely have a thermal protection and the output is reduced considerably as the temperature of the heatsink reaches a certain point.
Streamlight's ProPolymer 4AA Luxeon seems to have a similar protection with the output dropping slightly and the heatsink temperature stays steady once it reaches a point.
RiverRock K2 offers no protection at all and it allows the LED to reach a temperature in excess of 170°C (at heatsink, higher in the chip).
Anyone know if the Fenix and other aluminum 2AA flashlights offer thermal protection in foreseeable undesirable conditions, such as being activated inside a jacket pocket? If a L2D was to be turned on at full power in blankets, would the temperature be limited below what could cause a permanent damage to itself or start a fire?
Edit: RiverRock has no protection, which was able to reach 170°C at heatsink under good insulation with 3 NiMH batteries.
My result:
Mag 2AA LED: good insulation and NiMH batteries caused the body temperature to stabilize at 51°C.
Streamlight 4AA Luxeon: Input current and output are slightly reduced after the few minutes, but heatsink temperature remains steady. This suggests active thermal protection.
Others' result:
Newbie's test showed MagLED powered by 2C cells climbs up to 72°C in the first ten minutes of use as the light output declined steadily.
https://www.candlepowerforums.com/threads/119665&page=1&pp=30
Tests I conducted:
Other's result:
Original thread:
My result:
Others' result:
