Re: Noooooooooooooo! can\'t open LE
Originally posted by Graham:
. The foam retainer was a pretty messed up though.
Graham
<font size="2" face="Verdana, Arial">Thank goodness for SASE eh?
Anyway I had a little thought...I think the general concensis is that it's a vacuum holding it shut, but either way be careful opening it because if it happens to be the opposite of a vacuum you could have Arc head flying across the room
Now seriously, if it is a vacuum then there are 2 tings in play I'd think...
Pressure at pressutization and...
Water temperature
What I am saying is that there was positive pressure at 9' but then as the pool water cooled it expanded so that would help to equalize the vacuum wouldn't it and why am I still going on and on...
Ok so now that I've got my thoughts out on LCD, lemme try again.
IF the pool was warm when you came out the water eventually got cold and when water gets cold it expands (Hey! Now my comment about it maybe being a pressure situation instead of a vacuum is starting to make sense) meaning that the vacuum is probably not as bad as it could've been. I think we need to do some calculations and make
sure it's a vacuum in there and not a pressure type situation. Now if it is a vacuum than getting it even colder (I.E. more water expansion) should help things out right? So Darell was wrong
you don't need to go diving in 9 feet of boining water, you need to go diving in 9' of ice water! Stick your LE in the freezer, or fridge anyway, for awhile and see if that helps!
This is getting long isn't it! Ok...
SUMMARY
You changed the battery at 9'
Pool water got in
Pool water is warm
Air is cold
Pool water expanded, but the pressure difference of 9' is still in play here...
Get your Arc
cold
Try to open it
Good luck!
