geepondy
By now most of you have read that Arc Flashlight only intends to produce the LS2 for a very limited time, therefore a creating possibility that not all of us will have a chance to obtain one that wishes to do so. You know the advantages and disadvantages to both. LS2, probably somewhat brighter then LS1 with nicer beam (corona wise) and I would assume close to LS1 run times. LS3 much brighter, much less runtime, possibility of thermal shutdown in operation. Peter has stated that for cost and efficiency purposes, he only wishes to produce one LS hence the short production time for the LS2 in the migration to the LS3.
So if only one LS in manufacture, which one would you rather have, an LS2 or LS3?
One vote for LS2.
One vote for LS2.
