cernobila
Are the electronics and therefore the performance the same on these heads if the same body/batteries are used?
gunga said:All the heads should be the same. If you see better performance with the same voltage, it is likely just sample variation... (assuming the battery chemistry and internal resistance is not limiting performance of course).
cernobila said:ok, so, the output of a 1x CR123 3V should be the same as a 2x AA 3V with the only difference being in the run time, correct?
