logicnerd411
Well, I was bored and I fished through a few nuts and bolts to find a normal sized nut which fit in the Arc's body. I took an AAAA and rested the positive side on the foam retainer hole and lowered the Arc's body into the battery. And guess what... it worked, as bright as it usually is! I don't have the time, but can someone try this and post runtime tests? Thanks in advance.
