Eskimonio
- Joined
- Feb 9, 2007
- Messages
- 135
Just received my $14 DX Cree Dropin that's supposed to fit the Maxfire LX. I had been waiting awhile, but it felt like Christmas, so I walked away from my hot dinner, removed the batteries from my Maxfire, and then removed the bulb/reflector/plastic reflector retaining piece from the Maxfire.
I dropped in the DX Cree item #1343
http://www.dealextreme.com/details.dx/sku.1343
and screwed the bezel back onto the light. The diameter of the drop in was not as wide as the original reflector, so it was sitting in there a bit loose until I fully screwed the bezel all the way down. Once that was done, things looked tight, so I reinserted the batteries and screwed the clickie back on.
Push clickie...no workie. Hmmm...removed the batteries to ensure the both positive contacts of the Energizer E2 Lithiums were facing the bezel end of the light...they were.
Re-screwed clickie and cycled it about 4 or 5 times...still no workie, not even a glimmer from the new drop in.
NOW THE PROBLEM:
On the fifth cycle...suddenly, the clickie locked up. Upon pushing in the clickie...it stuck in the down position, not springing back as it would normally do whether it was turned on or off.
Unscrewed clickie and the ~2mm worth of spring that normally sticks out of the end of it is now less than one half a mm. As I fiddled with that spring trying to pull it out with my nails, a little wisp of white came out of the clickie...it wafted it way up to my eyes 2 feet away and burned like hell -- definite scent of acid. Well the spring won't come out and looks like I porked my Maxfire. Well, at least the clickie. There was no smoke from the bezel end of the light, and the led looks as it did prior to insertion.
The batteries do not have any damage or leakage that I can spot via visual, and they are only a few months old, with less than 10 minutes total use. One thing I notice now after I look at the DX product page is that the Cree dropin unit I received did not come with the larger circumferential spring...mine does have the O-Ring, and what I received looks exactly like this (with the exception of the larger spring in the top right of this picture):
Did not having that extra spring short out my Maxfire or what happened? What's my best course for resolution?
NOW THE PROBLEM:
