Aepoc
Hey all,
I recently purchased an Ultrafire C3 from Deal Extreme. I took the mini star out and swapped emitters with a UV Cree. All went well until I put a 14500 into the light and fried the emitter. I then took the mini star out again and put another working UV Cree emitter on it. Then I soldered all of the connections together and the light still didn't work. I tested the emitter-star connection and it worked fine. I believe either the circuit board is fried or there is a defective wire. Either way, I wish to take the circuit board out of the sandwich assembly without harming anything (especially the board). Does anyone have any suggestions? Has anyone successfully done this yet?
Thanks in advance
Thanks in advance
