OK, I did some "out the front door" tests. Out the front door for me means 200+ feet to the road through a bunch of trees, out to where the coyotes hang out waiting for little dogs to snack on, so it's a pretty fair test.
I don't have an E2E but I used a Z2 as reference, which with P60 bulb is just a tiny bit brighter than an E2E as far as I know.
The Terralux TLE-6EX running in a 3D mag with 5 1/2-D NiMH cells was IMO about the same as the Z2. The Terralux is supposed to be brighter and probably is, but to my eyes the ability to see was about the same.
The previous results are after I slightly defocused the Mag to get the same spot size as the P60 bulb in the Z2, ie my best attempt at apples-to-apples comparison. With the Mag set for tightest focus it had a tighter, brighter spot than the Z2/P60 and noticeably better throw, ie I could see the road (200 feet away) clearly with the Mag/Terralux but only dimly with the Z2.
I then replaced the Terralux LED drop-in with a GH24 10W incandescent bulb. Now the Mag was noticeably brighter than the Z2, and let me view the road clearly with a decently large spot. Remember I'm running on 5 1/2-D NiMH cells not 5 D alkalines so your results may not be as good. Alkalines just have too much internal resistance to be good at driving really high currents.
OK, so what's the bottom line ? My guess is that the GH24 will be just a bit too much for your D alkalines. I have to second the recommendation for the cheap 4 cell Mag Krypton bulbs (2 pack is a couple of bucks at Home Depot) and suggest you pick up one 4 cell Mag Xenon bulb as well. The Xenon bulb *might* flash on new alkaline cells although it worked real nice on 5 NiMH cells.
I just tried the 4 cell Xenon with 5 NiMH and it is *much* brighter than the Z2 with P60 bulb. The Xenon bulb gives you a very small, bright spot while the Krypton bulb gives you a larger, slightly less bright spot.
Try both. An occasional
is not the end of the world.
The Terralux will use your batteries much more efficiently -- the current draw is maybe 1/3 amp which means you don't waste much power heating up the cells, and the regulator keeps the light bright until the cells are nearly dead -- but you're looking at 25 hour runtime and only a bit more brightness than your E2E. Putting the Mag bulbs in will give you more brightness, but only maybe 6 hours runtime and some of that will be dim and yellow when compared to the initial brightness. The GH24 bulb will only give 2-3 hours of runtime but somewhat more light. I'm not sure it's worth it.
I say play with some 4 cell Mag bulbs and find what works best. Have fun !!
If you're into specs and data sheets the Carley web site seems to have good info. I'm not 100% sure that these are the same bulbs Mag sells but it sure seems that way :
http://www.carleylamps.com/star.htm
Note that they clearly recommend only the lower current bulbs (the ones Mag sells) for use with Alkalines and reserve the higher current bulbs for rechargeable cells. It's not the rechargeable-ness that matters, it's the fact that rechargeable cells tend to have much lower internal resistance so are able to drive high current bulbs MUCH more effectively.
