Hi All,
I have a small problem with my Arc LS first. About 95 to 99 percent of the time, it works flawlessly. However, occasionally when I turn it on, it appears to be in some sort of dim moon mode or something. It doesn't happen very often, but it is somewhat aggrevating. It still works and turns on and off normally, but it's only about 1/3 as bright.
I can unscrew the head almost all of the way and shake the battery inside it and it fixes the problem sometimes. Other times, I have to completely remove the head from the body and re-attach it and the problem is fixed. This problem seems to occur with all my battery packs, so it's not the batteries or the packs themselves.
I keep the light clean and use the two different Surefire lubricants I got from jtvat on the threads and o-ring, so that's not the problem.
There appears to be a light surface scratch across the middle of the gold board (pcb?) inside the head where the positive battery tip makes contact. However, I don't think this is the problem.
My delima is this. I love this flashlight and don't really want it replaced (even though I'm sure Peter would gladly do this if needed). And, I would prefer not to have to send it in to Arc for an evaluation. The beam is bright and perfectly centered with just a hint of the green tint to it and I love it.
Any suggestions on what might be causing this problem would be appreciated (could it be this flex/flux problem I've heard about and what causes that?).
Also, if the gold board inside the head ever wears down from battery contact, is this something that is replaceable by Arc over the years?
Thanks for any help.
